MIsterious Vaper
  • Full Name
    leo misterious hansen
    North Bay Ontario Canada
    wismec
MIsterious Vaper's Achievements
  1. i am trying to find out what type of power supply i would need to use to have plug in wall option i need to know type of output from the power supply i would need like how many volts and how many amps and if anyone has links to ones already known to work please share
  2. i will figuer it out in the meen time just going to order a triaid for now
  3. i am think of using a low profile fat daddy 510 for the replacement
  4. i going to keep the mod i love it just replace and upgrade the 510 connection
  5. mine is pretty much stuck down some of my attys wont work cause it stuck down pretty much have to use one of my heat sinks to get most to work so i guess i just gona replace it with a new upgrade when i get the chance to
  6. i have had this mod for about 7 months now i know the 510 connection is kind of stuck down i guess it time to replace and upgrade it thank you for the help
  7. i am wonder from mech mod experience could it be the atty them self with some kind of difference like a voltage drop or something
  8. soft cut is 3 volts coils are not spaced and no hot spots but this happens even with a full charge and haven't tried a single coil out yet getting similar results with my avocado 24 with 0.2 ohm build but 0.6 watt differance on the display of the mod
  9. and i am using kanthol
  10. here is a screen shot
  11. i have the wismec dna200 using a griffin with dual fused claptons 0.18 ohm i have it set at 80 watts but when i fire it reads 79.1 watts i set to 85 watts and fire at 84.1 it is always 0.9 watts lower then what i have it set at also useing samsung 25r batteries i have three sets and this happens with all
  12. i had similar issue with my wismec did case analysis and also did atomizer analysis for each profile setup and has since been no problem as to under power anymore hope this helps
  13. could not do screen capture so used phone to take pictures hope this helps
  14. it is the wismec rolo i will try and get a screen shot for you and i have had this mod for six months and last updated it a month and everything was fine untill yesterday when this started out of t he blue
  15. today for some reason my dna is acting weird i have it set to 80 watts but when firing i will only go 78.2 watts on the screen and in escribe tried different attys and builds and different set watts no matter what it always under fires at average of 1.5 watts then what i have it set at i am using the wismec dna200 with samsung 25r batteries and it happens with all three sets i have
