been running my 317L with this profile for the last hour and it is regulating the temp a lot better im getting a more satisfying and constant vape experience now thanks for that Jaquith works a treat
im around 0.16ohm 10 wrap 3mm bit with 24awg and that a micro coil no spacing i preheat my coils to heat evenly but u have to be sure not to heat to much or u can ruin the coil if u let it burn cherry red if u see white residue on your coul after dry burning it its time to start over again
i tent to use just a damp rag of tissue seems to get it off mine is a 520 100w on the velocity so u should be getting a lot better results then u are i suggest u try a coil after u clean the wire and see if that makes a difference
i vape mine ay 520 on a dripper did u clean it before u built the coil ? as there is a black residue on the wire when u get it that has to be cleaned off before use
what titanium are you using ? that aint normal i vape titanium and coils last a hell of a long time to the point where it dont need changing but i get bored with it and wat to try another build
