Milkweed
About Milkweed
  • Birthday 11/17/1979
    Malaysia
    Dna 200
Milkweed's Achievements
  1. I'm sure they do but it wont get pass the checks here. I'm on my own. Still sourcing for a good rc batt locally that will fit.
  2. Yeah...i'm still getting it replaced no matter. My only worry is if it still wont work with a new batt. I come from a place where evrything is almost impossible to get. But thanx for your input anyway.
  3. How would I know if it's bad..?
  4. I pretty much think so too. Battery is bloated quite bad. But would a bad cell show on escribe? Cause evrything looks normal there. I'm still getting a replacement battery though.
  5. My device is almost a year old and recently cant hold a charge for long. I was about to get a replacement battery but something happened yesterday night. After re-wicking my Mage RTA, put some juice in it and fired it up...that's when it happened. Screen went blank. For a moment, I thought it was a blown fuse but the screen came back on a minute later. And from then on, the mod would just restart whenever I fire. Screen would go blank and come back right on. Could it be just a bad battery? Cause I checked the fuse and it was still good. All the settings are gone too.
  6. My VT200 merely fell from a standing position then there was something loose inside. I opened up to find out what was loose and turns out one of the 2 square capacitors or what-nots had came off. What poor work!! So what do i do now?
  7. Noted. With that said, what temperature and wattage are you firing at? I had mine at 0.0038, set at 450F and firing at 35W. Am i doing it right? Seems better then what it was with my first experience.
  8. Anyone else was successful with such build and uploading the csv file into escribe? @Mad Scentist perhaps you can share your csv file here....
  9. Anyone found a good lipo battery replacement for the VT200? Been searchin high and low for a better battery but have not succeeded.
  10. I kinda thought so after keep tinkering with it and reading that part again and again. Too bad I had to return to my normal dual Ti build. TC was all over the place and my juice were turning brown. You know how they taste like when that happens. But I'm gonna try it again soon. Thanks for the help @Mad Scientist.
  11. 1-1 exchange at Eco-Vape done?
  12. Let me get this right. So if my TCR was 0.006 I have to bring it down to 0.001 or just 0.005? And I think you mean 0.005 as the range is only 0.001-0.01. I also noticed in the temperature control results equivalents tab, it mentioned "To match it on a mod set to Titanium 1, adjust the temperature to ~210°C or ~410°F." and so I did. Seems a lot better than before. It was at 450F previously. What is this Equivalents tab suppose to be for? Oh....and thanks for the help.
  13. So I claptoned a 32g KA1 wire around a 26g TI1 wire. I saw a post somewhere on this build. I did 7 wraps over 2.7mm ID dual on my TFV4 clocking in at 0.24ohms cold. Got onto steam engine, parallel, clapton on both, input all the figures in but the resistance came out to 0.16ohms. Should i be using this to upload into my mod? Cause I did and the temp was way off compared to my full Ti build. Tank got rather hot after a couple of puffs. I thought it would be rather dangerous to continue. What am I doin wrong? Should i wrap TI1 over KA1 instead? Should i adjust the numbers on steam engine such that i get the same resistance as my build? Appreciate if someone could shed some light. Pretty sure other users are looking into this too. Thanks.
  14. How did it turn out? Would to try the same 32g KA1 clapton ard a 26g TI1 too. Did you manage to get the TC to work with the uploaded csv temp curve from steam engine?
