dampf-o-mat
Everything posted by dampf-o-mat
  1. So i sent an email to the reseller and they asked me to send the device back to them in order they could fix or replace it. Thanks a lot for your help and advice guys! Highly appreciated!
  2. Thanks for your reply. I made the update to the latest firmware version again but unfortunately the problem remains. Is this a warranty case now?
  3. Unfortunately changing the settings didn't help. I didn't use the Lavabox for an hour and now the battery icon is gone and when i fire the mod it just says "check battery". The the screen goes off and the device is locked. Some ideas what to do now? Thanks for your help, guys!
  4. I'll give it a try. Thank you, VapingBad!
  5. So i checked escribe now and changed the capacity from 8 Wh to 9.9 Wh (3-cell). I also changed the cell soft cutoff from 3.66 to 3.3 V. Type is LiPo, charging mode is "maximize puffs". Here is what the device monitor says: Cell 1: 4.03 V Cell 2: 4.02 V Cell 3: 4.03 V Are these settings ok?
  6. Thanks a lot for your reply. I'm at work now so i can't check escribe. But it's definitely on "3 cell", i checked that already. After removing the battery and putting it back everything seemed fine in device monitor. Isn't the lavabox pre-configured so watt hours etc. should be set correctly?
  7. I just bought a Lavabox. When i recieved it i recogniced that there is no battery icon on the screen and i can't fire the mod. I removed the battery from the box and put it back in, then the battery icon was visible and everything worked like a charm. Then i just let the mod sitting on my table for an hour or so (fully charged). When i came back and wanted to use it the battery icon was gone again and the mod didn't fire. Removed the battery again, put it back, everything's fine. After a while the same problem appeared - no icon, mod won't fire. What's wrong with my device?
