meloserj
Everything posted by meloserj
  1. @BillW50 @dwcraig1 Hi mates Issue resolved. I dismantled the board from enclosure and took out the 510. The spring of 510 was not what I expected in quality, so I replaced it with my extra Source V3 M10 510 Connector spring. Now mod is working without any issue. Thanks a lot for your kind suggestions
  2. @Wayneo I was exactly waiting for your comment. Because after taking screen shot, I looked to profile and then I changed it to profile number 2 and there again I run atomizer analyzer. The same issue observed. So I don’t think this would be a profile change and analyzer issue. Issue still persist and as you can see from device monitor, cold ohms are unusual.
  3. @WayneoHere you are mate
  4. Hi @Wayneo Yes I did try different atty. The same build on SC V2 plus and SC Ragnar installed (Dual 6 wraps of 26*3/36 in 3.5 mm Ni80 Fused clapton) and those atty's have different 510 leg length. No changes has seen. But DNA200/250 show exactly the same cold ohms. I even tried to check the 510 connector center pin and wires to DNA250C board, checked for cold soldering, but everything seems ok.
  5. Hi @BillW50 Atomizer analyzer saying 0.21 until 0.24 which is fluctuating and never stopped accurate. But as I told before, the device monitor shows live ohms accurately and cold ohm much higher. I was using mod stock theme, i even changed it yesterday to Gauges theme but no changes. I will update to Frank65 theme (hope to find it in download section) and will update you.
  6. Hello mates Just got my new Hadron Pro, before doing any SP upgrade, I realized that the cold ohm showing on main theme screen is 0.72. I fully charged my mod and then connect my atty with 0.15 ohm (sure about it as its shows the same on DNA200/DNA250). Hadron Pro prompted for new coil and I selected YES, but ohm now is showing 0.22 in cold situation (Nichrome dual fused clapton) I connected to Escribe and even device monitor shows the same. But when I fire Mod, it jumps to 0.156 which is correct. Then I updated the SP to 45 and still the same problem existed. Even on youtube, I can see the same wrong ohm showing (for example below review after 15 min timeline), so I wanna ask if this is normal? How I can know if chip is faulty or not? Thanks a lot for your kind help )
  7. This is exactly what I am getting! OMG, I was thinking I am the stupid one who doesn't understand ohm laws ! Thanks a lot to share this photo and I will wait for update of DNA200
  8. Thanks bro, yes the UD is vendor name ( http://www.yourcig.com/ ) Thanks a lot for sharing the files
  9. Files removed from filedropper bro. may you please upload them again? @Jaquith
  10. @Wayneo May you please send files again? Links are not working
  11. Hello mates I am new to TC mode, and I have a question regarding the best setting for my Wismec DNA200 mod. Currently I purchased MKWS 316L Stainless Steel with 24 AWG coils, on my Griffin25 I made dual coils and resistance is 0.12 ohms. I downloaded SS136 /Elite from steam engine and it gives me poor vapor. So I searches and downloaded a CSV file which is attached. I am not sure if its ok or not. My config is 40W with 80W preheat at 4.9 for 1s at 450F. May someone instruct me what shall I set correctly to have big clouds and enjoyable vape on this device for the mentioned coils? I mean all wattage and preheat parameters and temperature with correct CSV. Any kind help is highly appreciated. DNA200-UD-SS_316L_DJaquith_V4.csv
