machobear
Everything posted by machobear
  1. Hi i think I've sorted it out for now. I did the following. Cleaned the 510 connectors. Changed to space coils on SS as it was likely coil gunk that was messing with the temp readings? Also I didn't lock the resistance. Should I be? I'll have to use it a bit more to see if the problem re-occurs. Power mode with Kanthal has returned to the normal as well. Fingers crossed because i love the way the DNAs deliver power, its just so smooth compared to my other mods. Thank you for responding Rob_H
  2. Hi, I just recently got a replacement efusion duo. (fuse blew in the first one). Ive been using this one for a few days with no problems till last night. All of a sudden SS316L temp control started going mad. My NarDA clone started spitting like mad and heated up really fast and was unvapeable. (0.78ohm clapton 28w Single coil). I tried my Goon 0.25 dual clapton SS316L 60w. Same thing just started spitting and heated up crazy fast and was unvapeable. Both were pretty smooth vapes and temp control was working fine. Both have preheat set to 80w 1s. I then tried my mage rta with a dual 0.32 clapton Kanthal coils in power mode @45 watts and noticed it was warmer/hotter vape then usual. I'm running SP3 and I'm new the DNA mods so any advice would be appreciated as to why it suddenly started playing up. Thanks in advance.
  3. OK.. Guess i have to send it back. Thanks.
  4. Hi i just got the fusion duo dna200 2 days ago. It just died mid vape with what was showing as 50% battery life. It was the second charge its had since new. I was using it in SS316L mode with 100w 2s preheat and the 45w normal vape. Ive removed my Mage RTA from it and plugged it in to escribe and it has switched back on what do i do now? Too add : IT gives a check atomizer error on three of my attys: MAGE, Triton mini & TFv4 Micro. Ive checked them all on my other mods and they work fine. There was no leaking and no moisture build up I could see. update too: its dead when not connected to usb. even tho the battery was showing 59% charge in describe. Any ideas?
