mui
Everything posted by mui
  1. mui
    SS316L Help
    Now that I fiddled with escribe more, I noticed in atomizer analyzer that it says room temperature is +10celcius more from what it actually is. Also the value seems static, no matter whether I try to cool the device or not. Is this to be expected, or might it cause TC to fail?
  2. mui
    SS316L Help
    Yes, just adding resistance would not be great idea, but having option to do so would be welcome. I havent had actual connection issues as coils are stable, tho 0.02 too low always, and it is not atty issue as it follows in similar fashion no matter what atty is. This happens on single one wire coils also. So i dont think it is build related either. Material difference could explain something? Ive been only using geek vapes ss316l Could this be somehow OEM lost vapes firmware related issue? / Some specific version that is affected?
  3. mui
    SS316L Help
    I believe this could be solved in firmware simply adding 0.02ohms to cold resistance if wire is SS316L. Or then again fixing the actual issue would be fine possibility too.
  4. mui
    SS316L Help
    I have actually used SS316L claptons with therion 133 for some time now, with different attys (griffin 25, limitless xl, tfv8) and couple different profiles for SS. Common problem seems to be that mod calibrates resistance too low for some reason, result is that I get too cold vape on TC, only solution so far ive noticed is to preheat coils a little, say 0.5sec on VW mode, then remove atty, make mod understand there is no atomizer anymore, attach it and setup it as new coil. After this locking ohms to 0.02ish higher than originally seems to fix the issue. Vape is now within temp range I wish it to be and stay there. When doing claptons, failing to connect only core is certain way to make this matter worse, eg. Mod wont stay in ohmlock anymore. I have no idea why this happens but I hope this helps someone
