JamesBlond
Everything posted by JamesBlond
  1. Same here since beta int. update
  2. I still have the exact same problem. I use a "fancy wire" the SS Stagger Fused Clapton from Vandy Vape as double coils 5 wraps on a gold plated high end dripper and replay works... now I made a parallel coil with this wire and a 0.75mm thick 316 ss wire and now replay is available but it will not be check-able and therefore not work. If coils get to sophisticated is does not seem to work. update: I changed the thick wire to a thinner kanthal wire with more resistance... now the resistance of the build went up from .04 ohms to 0.07 ohms and Replay woks now! If the resistance is too low it seems to have trouble.
  3. "Changing option from "restrict to viable coils" to "allow on dubious coils" in mod section at safety card" ..... this was the issue I had too... it will now accept most coils. Thanks Soulvape
  4. I have the same problem on a DNA200 with LiPo pack. It will go to normal again but now when it says 20% of the battery left it is actually empty and will cut off. Before it went down to 0% before cut off.
