ricsuth
Everything posted by ricsuth
  1. Fuse replaced, working like a charm now
  2. Will dig the multimeter out... cheers
  3. And the fuse does look intact...
  4. Would that happen mid-use? It died between firing, not plugged in. Replacing that fuse is going to be a ballache...!
  5. Hi all, My self built mod has been working great for 6 weeks and then suddenly cut off. Display lights up when plugged in to USB and the charge symbol shows. Device monitor shows amps going to the battery but none of the cells are charging. When removed from USB I get nothing. Any ideas? Fuse looks good and I've checked all the wiring...?
  6. Scratch all that - it's just kicked in! Thread closed (unless it decides to repeat the fault)
  7. EDIT: posted thinking you'd seen the last one...
  8. To clarify, it's just reading "0.00" but it's applying the correct voltage for my current atty...
  9. Hi, I've just put my build together and everything appears to be working fine except there's no ohm reading on the display. Any clues? Got it hooked up to a fat daddy v4 low profile. Just wondering what to check first...?
