Hi.
I'm on vacation since Friday and wifi is limited, I only use my phone internet, so I still haven't got a chance to try out the theme.
The mod is a Elcigart Prisma 75c.
I'll update as soon as possible.
Thanks. Have a great week!
I mean the green led lights up when I click fire, and the screen is light up, either in idle, or when I have the device locked.
Escribe 2 SP19
Version 1.1 SP33.2 INT
Actually, as I've been checking, all my dna75c devices do the same thing. I just never noticed because none of them lights up like this white delrin does.. But this should be able to be disabled. Any chance you can fix this in a firmware upgrade?
Thanks.
Well bud, maybe the attached picture can help you understand.. Not all mods are the same.
Obviously I've uploaded settings, multiple times!
And you're wrong about the fire button. 1s second of each doesn't fade from a color to another, just changes instantly, you need to have half second of each to get a fade effect. The issue is that it's not cycling correctly.
Hi,
I need help.
I´ve been looking everywhere and can't find a way to disable the annoying green led while idle/locked. I have nothing selected for normal operation but i can't turn it off. Is there a way to do this?
Also the fire loop isn't working properly. It goes blue red, blue red, instead of smooth transition from blue to red and repeat like it should be...
Hi, I need help.
I bought a new dna75c device that's not working properly. It gives me 0% battery at 3.5V.
I checked battery cutoff on Escribe and it's set to 2.7V, however I have 3.5V on the battery when I go charge it, while in other dna75c devices I own, the same battery is drained all the way to 3V,before it gets to 0%.
I can't figure out what's happening. Can you help?
Thanks.
Hi, I have a Lost Vape Triade with a dead chip. I love this box, so I was wondering if I could take apart my hotcig vt133 and use the chip on my Triade instead. Is it possible? What does it need to be changed regarding wiring, and box firmware? I have a friend with another Triade from which I can backup any data needed. Thanks in advance.
