moro80
Everything posted by moro80
  1. Thanks for the input. Was a bit worried about driving the temperature up...read some stuff about chemicals in the juice breaking down and what not at high temps. Nonetheless, good to know it is working the way it is supposed to.
  2. Folks, Maybe someone can help me. Here is my current setup: - Lost Vape Therion DNA 75 - Uwell D1 tank with 0.5 ohm SS316 coil. Primed the coil, let it soak in the tank for a few minutes, and then vaped at 40W and 460 Deg F, with the SS316 profile selected. Worked great, great clouds and flavor. After a few minutes of vaping, vapor production went way down. It reaches the temperature protection screen right away. Have to bump the temperature up to 530 degrees F to get decent clouds, while flavor is just ok. If I disable temp control, by setting the temp to 0, I'm back to getting good clouds and flavor at 35 watts, but a bit too warm for my taste and uses too much juice. Another thing I noticed is that when the temperature is limited, it reads a fairly consistent resistance of 0.52 ohms. If I disable the temp control as described above, it reads 0.61 ohms. Is something malfunctioning here? I would like to use temperature control to save juice and battery, but the experience is inconsistent. Also, the different ohm readings worry me a bit. Any advice?
