Quagmicah
Everything posted by Quagmicah
  1. Wayneo I actually haven't tired a single coil. I will try it today as I just received and atty that cam do a single coil.
  2. Temp control has always been finicky on every device I have used especially with the complex builds I like to use. It works perfect with simple round wire builds and twisted but once I start getting into multi-core claptons and aliens things start to get a little weird. It works maybe 50% of the time now that I unlocked the ohms and got the right profile set
  3. I will make sure to do that, I am always looking for new builds to try.
  4. I just tested another RDA with a simple spaced stainless steel build with the stock profile and device monitor is showing it is working perfectly. You where right with it being a build issue. Thank you for your help.
  5. I dont think it is a shorting issue and I made sure the connection is good and clamped down, they work perfect in wattage. I am currently letting it cool while not attached to the mod. I will change my profile to see if that helps. I will also try that build, thank you.
  6. I recently got a Lost Vape Triade DNA250 and was enjoying the temperature control on it. Earlier today it stopped working and either said temperature protection or would read a ridiculous temperature of 41 thousand degrees. My build is dual SS316L Aliens and I have a CSV from steam engine for the profile. Does anyone know what the issue could be? Thank you in advance for your help.
