nneuvdast8
Everything posted by nneuvdast8
  1. My mod resistance is set at 0.004. Will check it later.
  2. I use values within that range - 0.00088 - 0.00105, depending on what kind of SS wire. For UD, I normally use 0.00088. Beyond that value, I get dry hits before the TC kicks in. But this was with non DNA mods I have. I tried to check the connection and tightened the screws earlier. Its vaping almost the same as with the non DNA mods now. The varying resistance is quite normal for my TFV4 as it is an old atty I have for around a year now. But for the Serpent Mini 25, its kinda strange since I just got that atty the other night and the mod a day earlier. The mod resistance is 0.004 which I think is just about right. Thanks!
  3. I got a new tank, Serpent Mini 25. Built a UD SS 316L wire. 7loops, spaced coil. Reading was around 0.31 ohm. Tried to make a custom wire by TCR value, same result - the temperature does not have a read-out, it just states "OFF". Went to steam engine and tried to generate a new material for the said wire. Uploaded it on to my mod via eScribe and tried it. Voila, the display items were displayed as I've set it on eScribe and the temperature read out works as it should. Now vaping at 35W, 350F with the pre-heat set to 40W, 5 pre-heat punch at 0.25secs. The only problem is that, the curve, compared to what I ideally wanted was quite lower than that of the curve using TCR value, thus, flavor was a bit less. Is this problem being caused by creating a material with just the TCR value? Also, using the Analyze Atomizer feature in eScribe, do you guys get a constant resistance reading with the mod and atomizer reading? Or does your reading fluctuate? Both the TFV4 and Serpent Mini 25, when analyzed in eScribe shows fluctuating resistance (even without unscrewing it just a bit from the mod). Is this normal? It says that the resistance should be constant. Thanks!
  4. Will check it now. By the way I'm using Smok TFV4 and TFV4 Mini atomizers.
  5. Hello there everyone. Im quite new here. Actually, the Therion 166 is my first DNA Mod. I've been using TC for quite sometime now, specifically UD SS316L wire with other mods that have adjustable TCR values. I can say that I was quite satisfied with it. I opted to get the Therion to have a "more accurate" TC vaping experience. So on to my problem. Using eScribe, I created a new material, using TCR value instead of the CSV from Steam Engine. Used this material in one of my profiles and uploaded it to the Therion 166. It vapes great, with flavor and clouds, just like in my other non DNA mod. The problem is, the Temperature reading does not function properly - instead of having the temperature reading when the mod is fired, it just displays "OFF". More often than not, it will work as it should (showing the temperature reading when the mod is fired) but only for a few seconds after disconnecting the Therion from the PC. After that, it returns to the OFF display. Also, I cant seem to change the 3 display details beside the battery (OHM, Volts, Amp). Every time I try and change these three display items in eScribe, after uploding, the mod still shows the previous items. Anyone can shed light on this? It quite annoying. haha Thanks in advance!
