thelateoctober
thelateoctober last won the day on February 23 2023
thelateoctober had the most liked content!
  • Full Name
    Devin O'Connell
    Lincoln, NE
    Custom DNA 133 1550p
thelateoctober's Achievements
  1. Final update - sent Matt at Maxamps the same info above, and they are replacing the cell. I may try the method you guys suggested to recover the pack and have a spare. Thanks again for the advice.
  2. Update - after two more discharge / charge cycles and an additional 36 hours on the charger cell 2 is up to 4.01v. My main concern is this - when I got it it stopped at 3.2v. After some cycles and charger time got it to 3.6. Ran one cycle and it only came back to 3.2. I'm worried that I leave it on the charger for a week to get to 4.2, then run a cycle and it comes back low again. I mean breaking in a battery shouldn't take a month but I'm far from an expert. Anyway, just an update.
  3. Yep I went until I got flashing. The guy from Maxamps said to run another cycle or two, giving plenty of time to just sit on the charger in between. I'll give that a go and see how it turns out.
  4. One other question - when cell 2, the low one, is hitting the cutoff at 3.1 the other two still have 0.4v give or take,, the battery meter still shows 6% and the mod still fires, just not at full power. Should I continue using it to get those other two down to 3.1 or do I need to stop?
  5. Awesome, thank you. I'm not positive I have any solid wire small enough, but if I tin some of my 24g that should work. Also might have a couple of the ground connectors that go around the 510, those would probably work too. I'm gonna continue with the recommendations from the Maxamps guy for now - if it gets to a point where in just over it il9ise this method. Thank you! One other question, I'll ask Wayne too - when cell 2, the low one, is hitting the cutoff at 3.1 the other two still have 0.4v give or take,, the battery meter still shows 6% and the mod still fires, just not at full power. Should I continue using it to get those other two down to 3.1 or do I need to stop?
  6. Painful is right. That’s exactly what it’s doing when I watch on eScribe. 1 and 3 bounce around 4.19-4.21 with less than 1 amp input current. The only thing that’s bothering me really is that it will go ‘idle’ for long periods where it is not drawing any current at all - just flat zero on usb current. But I did just speak to the guy from Maxamps, their customer service is top tier. He said it’s frustrating that it’s taking this long to balance out, but should eventually, with no negative effect on the overall or lifetime performance of the battery. So if I have to do this for a week or whatever I’m fine with it as long as the battery is fine in the end. And I’m confident if it doesn’t that they will replace the pack. Thanks again for the help.
  7. Did you solder tabs or something to the ends of the wires going into the charger? How did you get the other end into the JST? I feel like stripping a good enough amount and tinnijg it would be good enough, but I'd be interested to hear how you did it. Also - if I'm trying to charge cell 2, I'm going to be using (starting nearest the battery negative) the 2nd hole as my negative and 3rd hole as positive, correct?
  8. Morning. Update - I woke up this morning with cell 2 at 3.98, 0.05v higher than I've seen it yet. So somethings happening, I guess? I'm going to reach out to Maxamps and get their opinion as well. I discharged by using it. I did not record exact values of cells 1 and 3 when cell 2 hit 3.1, but yes, they were ~0.4v higher. I'll whip out the multimeter after I've had some coffee and double check. As fast as that charging method, using painters tape to stick balance wires to a juice bottle and stuff it in an 18650 charger doesn't scream battery safety at me. I understand what is being done and that there is probably nothing to worry about, and if I end up with no other options I will do it... But I also feel like I should not have to do that with a brand new battery from Maxamps. Thank you for your reply and help!
  9. So after three full discharge to 3.1 and full charge cycles I'm still seeing the same thing. Cells 1 and 3 at 4.2, cell 2 at 3.92-3.93. I've tried a recovery charge after each cycle, which does nothing. Any other ideas what might be going on here? I've built tons of these with lots of different brands of batteries, to see this from a Maxamps is really weird, and for escribe to also just stop charging completely at this point is also very weird, I've never seen anything like it. Literally zero input current, whether connected to escribe and device monitor, or via the normal usb I use, having changed display while charging to show individual cell voltages. The charging icon just goes away and it sits there at 3.9. I spoke with a guy from Maxamps this morning, he suggested the multiple charge and discharge but with no change I'll reach out again in the morning. The other option is forking out cash, at least as much as the battery cost, for a balance charger that will recover that individual cell. I feel like I shouldn't have to do that. Anyway, any other thoughts or ideas? I'm impressed with your ingenuity with your solution but it's not something I'm willing to try.
  10. Zero usb current, cells 1 and 3 bouncing between 4.20 and 4.21 as they have been, cell 3 just chilling at 3.91. It's been exactly 3.91 since I first connected it hours ago. Pack voltage still 12.32.
  11. I'll give it a shot quick
  12. It just dropped from 67 to 66 while plugged in. That's not charging.
  13. I'm just having a hard time believing 0.008 amps is charging. That's like enough to replace the power the screen draws while on and plugged it. And 99% of the time it's at zero. The board thinks it's full and isn't charging it at all.
  14. Whatever Maxamps ships at, around 3.5. It's not charging, USB current bouncing from 0.000 to 0.008 and back. I've installed dozens of lipos and have never heard of one taking multiple days to balance charge.
  15. It was on the charger for 8 hours at least. Once it hits 66% the charging icon disappears. And just shows the battery. Like it thinks it's full. Photo is on the charger, with icon not showing charging. It is balance charging, yes, but that cell won't go over 3.9. How long should I expect a 2250mah pack that arrived balanced to fully charge all 3 cells to 4.2v? Thanks for the help!
