Just received this for protovapor looks like a new screen for a different manufacturer...new markings? This hasn't been confirmed..just looks different to me the ribbon markings and red tab on screen film..any thoughts?
I did the swap..installed a dna200 board in the RX black case...love it..the black buttons were not a direct swap...had to modify them, black fire button had a hole in the back due to the RX tactile being longer and the black up and down buttons were to long and had to file the backs down. Main reason I did this was for the black and that it has a texture to the case
I will be checking if it's magnetic tonight...funny thing is I used the tfr for SS304 cause it was matching the resistance and it was working..thanks again for your help
I really want to know if someone has actually had this working because I've talked to a lot and they haven't...most say it works fine just use the wire wizard, wizard is definitely not working and want to know if I'm doing something wrong
I think steam is way off on my build 26g 3mm 7wrap spaced single coil it says my resistance should be about .145?? And when I build it the resistance is close to .5 and settles to .45, and thus is nife30 from stealth and I'm choosing stealth on the wizard
Ive been trying and trying to make a TFR for nife30 for the dna200 and I cannot get it to work for the life of me...has anyone had any luck with a TFR for this? Thanks Wire is from stealth and I'm using wizard for stealth..please who has really used this wire on a DNA200?? worked fine on my Mclass with tcr
