Markyt123
Everything posted by Markyt123
  1. Excellent! Thanks for the response. Learning as I go!
  2. Cheers for the response.
  3. I have a question which might be dim. I've run wire wizard with the coil spec I've built. The ohms generated is .6 on wire wizard I've installed 2 coils which reads .31 on my DNA 250. My question is; is the .6 ohm csv I've taken from wire wizard ok to install onto escribe even though with 2 coils the mod reads .3. Furthermore, does it make that much difference from the standard ss316 profile already installed?
  4. Thanks!
  5. Bit new to this, just waiting for a triade DNA 250. Will this profile work for 3 batteries?
  6. Beautifully explained. Thanks for your help.
  7. Thanks very much you guys. Only other question that is still unanswered is that when I fire, the battery indicator drains and then builds back up again back to where it was. Is that normal, should I be worried?
  8. I know a little knowledge is a dangerous thing so I'll be careful. I'll learn how to read the graphs. So tricky because I'm determined to get more knowledge but trial and error seems the only way. Forums are great but I'd just like to be able to find some decent literature or someone to sit and talk me through it. Hey ho.
  9. Thanks for the post. I was a bit worried that the battery level dipped and then climbed again. Used to lithium ion just reducing over time. Might end up that I'm just an out of the box vaper. But I'm going to persist and keep learning. Man needs a hobby
  10. Loaded the csv file. Now showing battery life but dips on firing to 50% then goes up again? 2 puffs and showing weak battery again. Saw your post re evolv lipo response. Basically, this thing is currently useless unless I can make it work. No tc because of reduced power under weak battery. Looking like a swizz. Should have spent £ 160 on a decent yihi rather than £ 100 on dna75 and 50quid on a new lofepo4 battery and battery charger. Might be an easy fix but if no solution then I reckon yihi vs DNA is an easy equation to solve! No graphs needed
  11. I'm new to DNA so any help would be appreciated
  12. Hi AMD trucking, followed your advice and went for lifepo4 but my battery indicator is blank? Have I missed a setting?
