kappertje
Everything posted by kappertje
  1. Thanks again for your time , I manually installed 1.2 SP5a. After that I get the message there was a newer version. (the version that was installed) And yes, every time I change a setting I uploaded it to the Therion. I will open a ticket at Evolv.
  2. Thanks for the quick reply, as you can see in the bottom right screen. You can see the SP version. Everything is up to date. i changed the setting temp protection to "Don't show" an back to "show message" no result. I also changes the time the messages show in different value's 1s to 1.5s and so on. When i vape, without the pc attached. The Therion stops at the regulated temperature but no message. (i hope you understand my dutch Englisch)
  3. There is a dry wick in there, cause I cleaned al my tanks for the skiing holiday
  4. One moment, now I get the message "check battery" when I hooked the Therion to Escribe. When unplugged, no problem.
  5. Hi Folks Question, Temp. Protection message does not appear on my Therion 166. Ti1 coil. I can see the temp is regulated in the device monitor of Escribe. Message of temp warning is turned on in the settings. Anyone? (Dutch englisch )
