VapePanther
    sc
    therion 166
VapePanther's Achievements
  1. Thanks for the tip.
  2. That works well. Thanks for all your help, I appreciate it.
  3. I think I may be doing the same... Any rdtas you would reccomend?
  4. Yea, im gonna vape on this fuji to see if i get the same problem while I check the avocado. Im hoping its the 510 pin and screw because thats my favorite tank and i dont want to have to stop using it.
  5. well I spoke too soon just hit it a few more times and its doing it again. here is a screen shot of the device monitor. Im starting to think its my avocado 24 thats causing this problem. I threw on my fuji gta, hopefully its just that rdta.
  6. I see that lol, they were pretty tight but one of them I was able to snug up a bit. I'll run the analyzer here in a few hours my batteries should be down to 25% by then. Is the case analyzer a one time thing or do I need to run it every so often?
  7. well it looks like the problem was my deck screws were not tight enough. i cant seem to get it to lock up again and im getting dizzy lol. Thanks for the fast help, sorry for the noob question and using the wrong profile.
  8. lol... trying to get it to lock up again. I just tightened the screws down. ill post a screen shot of the correct profile device manager here in a minute.
  9. Sorry about that guys, still trying to get used to escribe.
  10. Ok I will tighten my screws and clean my pins, and see if that fixes this. Thank you again for your help and the csv.
  11. Yes I did upload it to the device. It normally does show my current temp when at max temp, it is only when the device gets "stuck" at max wattage and i press the fire button does it show temp protection.
  12. I have checked my screws they are as tight as I can get them without stripping the grub screws. I did clean the pin on my avocado 24 a few days ago but will do so again as well as the pin on the therion.
  13. thanks for the reply. yes i did change temp protection to show temp in the setting thats why im not sure why its still showing that message. here are the screen shots you requested. I havent gotten around to setting anything for the battery. do you happen to know what i should set it as? i am using nothing but hg2 sets in this device.
  14. hello all, I just recieved my therion 166 in the mail yesterday and it has been working pretty well. I am having a problem though. if i do some chain vaping on it, its like the temp gets stuck at whatever my max temp is set to and then when i try to hit it, it just says temp protection and I get no vapor. I also have it set to show temperature not temp protections when it hits max temp, so im not sure why its showing that message instead of my curret temp. If i then turn my temp up to 600f (have max temp set to 500f) and hit the fire button it shows at being at well over 500f even minutes after i have used it. I have it set to 70w and 500f preheat is 95w for 1 sec using steam engines's 316L file (I initially had it set to 50w and 420f with the same results). the wire im using is 3 core ss claptons from advanced vape and i have them spaced. the build is coming out to .12. Anyone have any advice on how to fix this problem?
