dusk1911
Everything posted by dusk1911
  1. I am on the same boat with a reaulaux
  2. Everything is just normal. Where do you go about opening up tickets?
  3. All the cells are fine and balanced. No screen disconnects reported. I don't have a meter around. But what are you thinking
  4. Hi I have had the reauleaux for 2 months and it was working perfectly.. I built a 430SS coil and while dry firing it I heard a click and the mod turned off and wouldn't turn back on.. Connected to a USB charger it turned on and said warranty service.. Removed it from the charger and it continued to work fine and I didn't see the message again. Left it for an hour and it won't turn back on. So I connected the USB for a second till it turned on and removed the charger and it continues to work. If I leave the mod for 10 minutes it would still work. It will refuse to work if left for more than 30 minutes. In order to get it to work I just quickly plug the USB then remove it and its fine for the day as long as it's not left for a long time.. I took the mod apart till the chip and there is nothing wrong with either the fuse or anything else.. All is perfect. I'm stomped.. Any ideas?
  5. Just an update, if i also switch to a regular kanthal profile and switch back it works ! , i have tested this on my Lavabox and 44 and they all do the same thing. Wire is 317L 24G resting at 0.2
  6. Hey I have a vaporshark, TC stops working when the device goes to sleep, only starts functioning again if the device is hard rebooted. This is quite annoying and i think its because of the 9-30 firmware, is there any way i can downgrade to test ?
  7. Thanks ,, the battery WH is kinda strange
  8. Hey There, Just got my hand on a VS200, when i plugged it in, it asked for FW update which i did, but upon reboot it said that the configuration is not complete Could someone please post the battery setting (i currently have it on 9.99 with 3.09 cutoof) and the Case Thermals ?
  9. Hopefully it will be seen
  10. i just signed in to propose the same thing, i dont want to see the --F on Kanthal, and dont want to see the Voltage on NI Wish this is really implemented
