mxadam
Everything posted by mxadam
  1. efest 3500mah 20a batteries retird ill do the screenshot tommorow
  2. the question is mainly, if I set it at 70 watts, should it fire at 70 watts till the battery dies, like my dna 200? or will the watts drop as the battery charge drops like a mech mod. Surely if I want 70 watts, I set it to 70 watts then use it at that till the battery dies, currently the hit just gets weaker and weaker until I then pop a new battery in. If it will drop as the battery drops then im sending it back as its not fit for use without running it at like 30 watts or under. Wont even fire 70 watts, full charge with 0.18ohm coil.
  3. in a bit, it will fire at 40, then 35 as the battery is dropping in charge
  4. like now, its 1/2 battery. 0.18ohm coil. set at 70 watts, it will fire at 45!
  5. sorry i was supposed to say 0.18ohm
  6. sorry my bad i ment 4.2, I thought a fully charged battery was 4.4 . I use a battery charger and not the mod itself. Also I have tried 0.2 ohm coils upto 0.7 ohm coils and the same happens, its easier to use with 0.7 as using only 35 watts it doesnt drop under that until about 1/3 battery. But if using a 1.8 ohm dripper at 70 watts you cant get 70 watts even if full and it just drops and drops as the battery depletes.
  7. Hi all I just bought a dna 75 vaporshark switchbox a few days ago. When the battery is fully charged to 4.4v It will only fire upto 68 watts. As the battery level drops the watts drop like a mech mod. eg 2/3 battery 45-50 watts, 1/2 battery 40-45 watts, 1/3 battery around 30 watts Is this a bad chip, should I send it back? my hcigar dna 200 vapes at whatever watts until battery is dead, shouldn't this act the same? Thanks
