Ok peeps tried locking and locking stealth mode in and that is not the case It was in another mod I had built working flawless 1590 A+. I took it out was in the process of building it in a G+ with dual 18650 sled. Got it all soldered up mounted to my board holder decided to hookup to escribe to switch to 2cell and thats when I noticed the screen had stopped working. I'm going to finish the build except for epoxy and see where I am at at that point. I have emailed Evolv about a replacement screen or eta on screens. At this point I may just sell what I've got and call it a day!? Thanx everyone for the help and suggestions.
I can't remember but does the screen come on with just USB and no battery attached? Was using it in another box with a lipo. Switched boxes, board holder and was about to solder up dual 18650 sled decided to hookup to escribe first to change to 2 cell and the screen doesn't come on. Escribe reads, uploads and downloads fine? Please help I am so frustrated I want to throw the whole thing in the trash!
Thank you Megaton/VapingBad. I think I must have played with the curves at one time. After I did a reset to default on the device battery is charging full and the wake/sleep mode isn't acting up.
Ok I'll keep that in mind. I do have a Dark Horse RDA I could test with.
Also I went into Escribe and did a master reset to default settings. Gonna leave them at that for testing.
The battery was at 98% before I did this and after it was at 90% and charging.
No I have not changed the ohm lock range it's still set at default. If it was issues with the 510 would I not have issues under normal use? As for the battery thanx for the info I can deal with it.
Every time when my device goes to sleep (like maybe 30 minutes) and I hit the fire button it comes back on like first powering up displaying splash screens and asking me if new coil or not. Is this normal or is there a setting somewhere I'm missing? Also battery has never reached 100% only 98% even after 24 hour charging? Running Fullymaxx 900mah. Other than those 2 things the device works flawlessly. Hardest hitting mod I have! Love it
