musicbox
Everything posted by musicbox
  1. Thank you!
  2. Good evening. Help to find the stock firmware for Think Vape Finder 167 (ser.№JEGHOMPAFCGX) , or the latest service pack. (errors works on thermal control) Thank you.
  3. Hello. It does not measure resistance when the button is pressed, "fire" (can't a video file to attach, more than 10MB), and of course does not supply power to the atomizer. And it is not only battery change, ie: You've used the mod, then put the mod on for example 20 to 40 minutes, the mod went to sleep, you want to use immediately - and he again doesn't see the resistance. - this is the main problem. Other dna mod, this is not a problem. They give power to the atomizer when you press "fire", even before the screen lights up, i.e. instantly.
  4. Hello. No, it's another mod. The display shows "check atomizer" long enough, then determines the correct resistance. (compared with others on dna mod finder 133; finder 75). And then the mod works, you can remove the atomizer, put back, everything is OK. But if you remove the battery, everything is repeated again.
  5. Hello. Device "XvoStick mod based on DNA60" purchased new. At first everything worked fine. After connecting to escribe, and updates incorrectly determines the resistance: After replacing the battery Board is not immediately determines the resistance; after the transition Board in the Regis "sleep" and pressing the "fire" right away does not determine the resistance. Check atomizer and battery in parallel was carried out on 133 Think Vape Finder, it all works fine. A further update, checked all connections and rations. The problem is not resolved. What else can you do? You can send the "factory" firmware, for updating the Board? If you send in, and after updates, will not work properly what to do next?
  6. OK. I'm going to contact Mini ECIG.
  7. Hello. Thank you for your answer. It XVOStick Monolith (MONStick) from Chels. Mod new. Probably a defect in the production?
  8. Firmware version: 1.2SP3 Serial Number GJGP ZSHV HHON
  9. Hello. The question of self-discharge. Current consumption at rest 88 mA. Discharged the battery to zero less than a day. Squats: the Batteries were taken different. Set up the Board has established a standard by using escribe. What are the options ... or dying fee?
