soldier05354
Everything posted by soldier05354
  1. Version 1.0.1
    232 downloads
    Built with Factory Enhanced Platform to keep everything working including Replay. Several modifications keeping the overall default Evolv theme Capabilities. Simpsons Walpaper Theme Very colorful On main screen when not in active Replay saved puff you can select the ohm reading to shortcut you to the Coil Info screen. Settings changed to Menu for new menu / settings platform Most "Back" buttons removed and scroll up of down off the screen to go to the previous screen. Watts now adjustable in 1 watt increments instead of .1. Temp adjustable in 5 degree increments. New menu platform dived into Profile, Puff Info, Coil Info and Settings on main menu. New coil install screen now has cold ohm temp for new coil and old coil resistance and temp when deciding on new coil or keeping old settings. Profile Menu has added cold ohm temp with current ohm reading and coil material setting added. Also added is the availability to have advanced preheat settings with the Preheat+ toggle when temp control is active. Puff Info screen enhanced with chart and ability to change wattage and or temp for dialing in a perfect puff. Also the addition of several live readings of the last puff. Live ohms, room temp,average power, puff duration, puff volts, puff amps, and average puff temp, and max puff temp when in temp control. When a non-temp sensing coil is installed gives you current battery % instead of temp. Recording Screen with new additions to be able to monitor with every puff. New Coil Info screen added with time, battery %, current profile, coil material, cold ohms, live ohms, coild temp, ability to remeasure resistenace, and ability to lock ohms. New settings menu with System, Display, Device, and About. System gives you date, time, 12 / 24 hr, F or C temp, max puff time and serial number. New Display menu has brightness adjustment, always on, stealth level, auto lock, auto lock time out, and # of clicks to lock, and ability to set unluck device sequence. Device screen now had power bank settings, and battery voltages for up to 4 batteries. About Menu with Lifetime puff count, Theme revision, current firmware, current revision, edition, current puff count, puff count total energy, and reset to take you to a rest statistics screen. Thanks to everyone on the Evolv forum for ideas and themes to give me inspiration for this theme.
  2. I designed these battery icons for a black Walpaper Theme. Download them here https://drive.google.com/drive/folders/1LtBOvoSLKn6_ofc_BVwywr8no9Lx-ikk?usp=sharing Battery Charging Empty Black Backround Horizontal 16x32 Battery Charging Empty Black Backround Vertical 16x32 Battery Charging Empty Black Backround Vertical Battery Charging Full Black Backround Horizontal 16x32 Battery Charging Full Black Backround Vertical 16x32 Battery Charging Full Black Backround Vertical Battery Discharging (Power Bank) Empty Black Backround Horizontal 12x32 Battery Discharging (Power Bank) Empty Black Backround Vertical 12x32 Battery Discharging (Power Bank) Empty Black Backround Battery Discharging (Power Bank) Full Black Backround Horizontal 16x32 Battery Discharging (Power Bank) Full Black Backround Vertical 16x32 Battery Discharging (Power Bank) Full Black Backround Battery Empty Black Backround Horizontal 16x32 Battery Empty Black Backround Vertical 16x32 Battery Empty Black Backround Vertical Battery Full Black Backround Horizontal 16x32 Battery Full Black Backround Vertical 16x32 Battery Full Black Backround Vertical
