natente
Everything posted by natente
  1. Fixed CB; self-inflicted lack of charging here Unticked the box 'This mod uses an external charger' and voila
  2. Thanks CB In between your and my post, I rolled back to 2016-05-02. The LED flashed red briefly, the battery bar still shows "charging" regardless of "USB Charging" disabled or enabled. Upgraded to 2016-06-05, device monitor still shows "charging" and cannot be disabled. Confirmed LED charge colour in eScribe is RED, and it's not changing to red either EDIT: when did I update? A while ago admittedly, I cannot recall when specifically. Was probably shortly after receiving the unit late last year. Is there a "factory reset" or firmware reset for the DNA75? This is the SMY SDNA 75
  3. FIXED: Unticked the box under 'Mod' which is 'This device uses an external charger': https://evolvapor.forumchitchat.com/file?id=3215528 Odd..... I have just noticed since last update that the DNA75 is playing up during USB charge. DNA 75 with Escribe firmware from 2016-06-05 (latest update AFAIK) 1/ Plugged into the computer: the battery bar indicates the device is charging though the LED/colour doesn't change to charging colour (red) 2/ Plugged into the computer: click 'Disable USB Charging' via device monitor, and the battery bar still indicates that the device is charging (LED remains normal colour at all times) 3/ Plugged into the computer: click 'Enable USB Charging', no change whatsoever 4/ Plugged DNA75 into micro-usb cable attached to iPhone wall charge; battery bar indicates device is charging though, LED remains normal colour EDIT: can Disable USB successfully on both my DNA200s..
  4. Thank you very much
  5. Has anyone come across this file, which would include DJLsb's configuration of the device "out of the box"? For example, the Wisemec Reuleaux DNA 200 .ecig defaults file: http://www.wismec.com/download/W009-151116-2.8V-CASEJB.ecig
