injen
Everything posted by injen
Hello ppl, is there any theme for mirage that support replay function ? Thank you in advance
OK, So WHEN is this NEW software for the 75C coming out?
injen replied to Joe M.'s topic in DNA 75 Color and 100 Color
guys how i can find the deault theme? i have a mirage 75c -
Hello ppl, Anyone can kindly provide me with a discharge profile for the lg hg2 or samsung 30q battery ? Thank you in advance
Just for a refference with the ni200 from gearspek which has the higher resistance per meter the temperature control works ok , with all other wires the vape is weak, it would be great if we can have an official post with what wire is the board calibrated by default
All of them were 26ga , so you say that no matter the resistance all of them will work the same in temperature control?
I used ud - stealth vape and gearspek , all of them have different resistance per meter, how you explain that ?
I' m just curious , what brand ni200 wire do you use ppl?
+1 by me , well sell said mate
I will try it asap and see if this also happening to me because the low TCR explains the weak vape
This may explain a lot of things
How you change the TCR in escribe? Isnt this fixed ? When you choose a material ?
I have seen them since theiir release ,
It should be able to play in temperature control out of the box like anyone other boards do , i' m really frustrated about the behavior of the mod.
Really, i tried everything , cant help you ,it just doesnt play
I' m sorry to hear that my friend but i tend to believe that is nothing you cant do, it is what it is , i have to live with this and use my sx mini in temperature control because dna 75 chipset refuses to work with my atomizer and builds. I wish i was able to provide you with a solution but as far as i can see noone can.
No , its set at 0.003 What ni200 do you people use ? Is it possible that the ud wire has lower resistance per meter than the wire the mod is calibrated? The sx mini is calibrated with temco wire and the closest i found is the ni200 from stealth vape which has lower resistance than ud wire, despite the lower resistance the sx mini plays perfect. Just to let you know that before kayfun 5 i had the kayfun 4 which due to the resistance the spring at the base had the VT was playing fine because the total resistance was more than the actual one . Now with the V5 which has solid connections to the base , so the resistance is only the resistance of the coil, i have the problem i described. I really want to find out what is happening and sell the sx mini and buy a lost vape triade dna 200 because dna chipset is far superior from yihi in temperature control , i cant fell and taste it. I forgot to mention that i tried nife30 from stealth vape and i had the same results
No i tried several builds with no luck , the mod reads the resistance at 0.10 and it vapes weak with the temperature protection kicking like hell, i make coils with 26 ga ni200 from ud 9 wraps on kayfun 5 at 25 watt and 35 preheat at 1 second but no matter what i do it doesnt vape like the q class , if i press the fire button and lock the resistance at 0.11 then the temperature protection doesnt kick so aggressively but that is note right. I dont know what else to do to make it play and as i said i love the vt75
Thank you very much i ll check asap
thank you for your reply , the temp limit on sx mini is 215c and on my vt 240c i think that with 240c would be ok but still hitting temp protection , the atomizer i use is a Kayfun v5 , both mods reads the same resistance I desperately want my vt to work properly with temp control and i cant find a way to make it happen
Hello ppl, has anyone run the case analyzer to vt 75 to import to my device ? It constantly hits temp protection and the vape is weak , i now use a sx mini q class and vaoes like train with the same wattage . I searched every possible setting in escribe but cant make my mode perform like the sx mini and i m really dissapointed because i love my vt75. So cant anyone upload his ecig file ? Thank you in advance
