            DanRyder87
                Posts19
Everything posted by DanRyder87
	It Still fires even when the screen is off.
	Ok so, My DNA Boxer 167 is all setup in escribe. I checked all brightness settings ect its nothing to do with escribe. Basically, When i press my fire button the screen goes off until i let go. However if i press it really really lightly, enough to get it to fire but hardly any pressure on the button then the screen stays on while it fires. But if i apply the usual full on button press the screen goes off??!?
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging Thank you my friend.
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging Oh right. So basically i need to think of 5% battery life as being my "Empty Battery" message and change batteries? Thanks alot. I can stop worrying now.
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging Yes... Its reading Ohms too High when i get down to like 5% battery. It doesnt fire. lol EDIT: Sorry i didnt see the mistake i made a few posts up. Its deffo Ohms too High
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging I have pretty much vaped 0.4ohm - 0.5ohm since i started sub ohming haha.
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging I dont like hot vapes and i care more for battery life than i do for clouds. At the moment the only wire i have is 26/32 Clapton wire and some clapton SS316L. I have some huge ass framed staple coils that i guess i could use in single coil mode but i dunno what a single coil is like in the aromamizer plus.
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging No my mod doesnt seem to do that. Il fire at 55w and vape it and it will just go cold as if its stopped firing. Then i look at the screen and it says Ohms too high
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging So you also have no clue about what he means? He stumped me. After inputting the correct CSV for my batteries and setting my Watt hours to 19 and my SCC to 2.75 i can get down to 5% before it says "Ohms too low" so im ok with that. I was just wanting to know exactly why it happened from the man himself. Im guessing if i drop my SCC to 2.7 instead of 2.75 il get the last 5% battery?
	  Ok Extremely Confused by the response from Ginger VaperDanRyder87 replied to DanRyder87's topic in Batteries and Charging Ok so i sent an email asking why i was getting an "Ohms to high" message when i got to 5-10% battery. only vaping 55w @ 0.47 ohms dual clapton. He told me i should NEVER ( he capped that) use Samsung 30qs or LGs in any mod. If i wanted better performance or battery life i should buy either VTC5r or His Boxer batteries. Even though they have 400mah less than the LGs and the 30qs they will give alot better battery life due to amperage? Im only pulling 4.89v and 10amps. Can someone tell me what he is on about? Why are 30qs and lgs never to be used in mods?
	I currently have a different CSV profile loaded for my 30q , Should i use your one?
	Here is the device monitor one http://prntscr.com/eubv0d
	http://prntscr.com/eubu8t That is the mod tab
	Oh right, So ohms too high is basically telling me my batteries are flat? Thanks alot. I thought i had a dodgy mod/ batteries. Was on the cusp of selling this dual 18650 boxer and getting a triple. Lol
	Hey guys. Just after some help here. Using 2 Samsung 30qs brand new. Basically when i get down to like 5-10% battery il get "Ohms too high" and have to change batteries. Im only vaping at 55w 0.47 claptons. How comes im unable to drain my baterries to flat?
	  Help please. Something is not right.DanRyder87 replied to DanRyder87's topic in Batteries and Charging I dont like to vape low ohm builds really. I dont like going over 55w either.
	  Help please. Something is not right.DanRyder87 replied to DanRyder87's topic in Batteries and Charging http://prntscr.com/etwz13 I noticed while firing that it never hit 100w on the graph to the left it said 85w and my mod showed "Ohms to high"
	  Help please. Something is not right.DanRyder87 replied to DanRyder87's topic in Batteries and Charging I cannot see how or where i can fire it at 100w. I tried firing my mod but nothing showed in the battery section of escribe. Would it be beneficial for me to load a 30q CSV file or should i just set the cutoff to 2.75 and leave it?
	  Help please. Something is not right.DanRyder87 replied to DanRyder87's topic in Batteries and Charging Hey guys. I have had this issue with every single DNA device i have owned. Efusion, Efusion Duo, Therio 75w , Therion 133 and now the Boxer 167. Basically, Every time i have about 2 vapes the % drops by 1 which i assume is normal and thats fine. However when i get to around 40-45% it suddenly drops to 20%. Example today i was vaping, looked at my battery and it was 46% had a few vapes and set it down while i played my xbox, after a while i picked it up and had a vape and then checked and it was down to 22%. This has done this since the day i got it. I even purchased some new 30qs and it didnt sort the issue. In Escribe i set my battery up. Only had three to choose from Lithium Polymer LifePo4 Power Supply Lithium Polymer was automatic set so i left it. I clicked Watt hour calculator and have it as Battery Cell Capacity: 3000 Cells: 2 Nominal Pack Voltage: 7.4 This gives me 22.2wh have i done this all correct? Im being told to change my soft cell cutoff which is set at 3.09v. one thing i would like to point out is that with a pair of 30q or LG2 i can get a day and a half out of my Minikin v2 and 50w ... Currently cant even get a day out of my 30qs in my boxer at 50w. If i vaped my batteries dead in the minikin when i put them on charge they would show as 3.1v however with my boxer when i put them on charge they are 3.4v. Is this something to do with it?
