Amirulmukmiinin
Everything posted by Amirulmukmiinin
  1. I know it is normal as the coil cool down, but my ohm reading is not normal at all, going to large variance reading and its getting high starting from 0.87 to 1.21 and 1.34. If there poor connection with my coil it is impossible because when i try on my other mod (vt40), the ohm reading is normal. I bet it is poor connection with my atty connector or wiring issue. how can i fix this? Can i fix it by myself or i need someone that are professional to handle this?
  2. My battery cover also has been tighten. I worried if i tight it too much, my battery cover will stuck and cannot open.???
  3. Still the same result bro. And i opened my mod twice to make sure there's no untighted screw.
  4. I dont know im using the tc mode or not, im gonna check it again later. I tried on atomizer analyzer and other mod, no jumpy ohm, but when i put any tank(doggystyle, hurricane jr and kayfun v5) on my vt75nano, all show the jumpy ohm. The worse ohm jump is from 0.89 to 1.21. And its getting high to 1.38.
  5. contact coil. i tighten the plate already so that mean no need to tight it too much? what does it by adjusting it up or down? sorry im not understand.
  6. nah after a minute my ohm still running bro. tighten all the screw but still having the same problem.
  7. done it! thank you so much bro! really appreciate it
  8. kanthal 28, 6wrap, 2.0 using doggystyle tank
  9. Hi i have a problem with my Vt75 nano about ohm resistance. my ohm is not set in every puff. every puff mean different ohm reading. Anyone can help? sorry for my broken english, i wish all of u can understand. Thanks
  10. if other country how can i reach them?
  11. this is the printscreen of my battery setting. when i use this setting (lithium polymer) , my mod cannot fire and show 'check battery'. and my battery display still empty
  12. Hi guys, im having a problem with battery display in my Therion 133 DNA200, i already reset to default, reset all the statistic and so on but it still show my battery is empty. Tried to change the wH and do all the things that i found in this general discussion like change the wh to 24.42, its work but not long, after 1 minute, it will leave my battery display back to empty. I also try to ask my friend that using therion, they said i need to change the battery type from power supply to lithium polymer but i cant fire and show check battery at my display panel. help me guys. thanks im sorry for my broken english but i try my best to make sure u guys can understand what im try to discuss here. below i attach my ecig file, please help me. thankyou guys Therion 133 dna200.ecig
