cgagne
Everything posted by cgagne
Well, got it back to the original settings, and still no Temp control. I tried new coils as well, with no luck. I appreciate you trying. Thank you good sir!
Never mind, I see the attachment you left. I read your message under the email at first, it didn't show the attachment
Yes!!! That's what I did!! Now your speaking my language. Lol. When I get home from work in the morning I'll give that a try......then go from there. So the file for the 166 is under-file- open file?
The 166. I can never find anything for 250. It's always 75 or 200.
Plus, they have the pre loaded profiles....it worked for those 2 days....they say I shouldn't have to use e scribe. Only if I want to make adjustments. I don't care about adjustments right now....i just want it to work.
Yea, I've watched a bunch of videos, read a bunch of forum stuff. Idk, I'm still not comprehending it. I work crapy hours, and have 2 kids. I barely have time to sleep. I didn't realize so many factors would matter just for me to vape. What day it is, the weather outside as opposed to inside, if I'm left/right handed. Lol. I just want to know what numbers go with what settings, so I can press fire and vape. I don't have time to take my laptop out and change settings every time I want to change my atomizer, or the weather changes. I appreciate your attempt to help me, but I think I'm a lost cause. Just sucks. The 2 days my mod worked in temp control.....i loved it!!! Then I plugged it in to escribe......never worked again.
Like my batteries were just at 100%. I've used it for 2 mins and it says 83%. I'm using 45 watts and took 4 toots.....17% battery used..... I really think all my settings got screwed up. I wish there was somewhere I can go where it will tell me what they're supposed to be
Wow. Smh. After reading that.....im even more confused. I didn't understand anything I was reading. The only thing I maybe got from that is, if I want to use my goon, instead of my Merlin mini, I have to hook this thing up to a computer and change all my settings?
Yeah I see where the case analyzer is and what not but I don't understand what it is and what it does after I do it or what It's trying to tell me. I'm just going to use the mod in wattage mode but I wanted to make sure the battery part was working correctly.
Oh, I know the battery stuff doesn't effect temp control. I just wanted to make sure my settings are correct. The first time I hooked my mod up to e scribe it seemed like a bunch of my settings got screwed up. Like it got changed to 3 cell. I didn't know if anything else got changed because I don't know what the settings are supposed to be. I can't seem to find anywhere to explain any of this in "English".
In the battery part. I'm running 25r's and LG brownies.....should my capacity be 18.5? Cell soft cutoff 3.09v?
I appreciate you trying.....im just hopeless. Plus it doesn't help I'm computer illiterate.
I've cleaned everything with rubbing alcohol. The screws on my goon 24 are as tight as I can get them. Mod resistance says zero? And unfortunately all the other stuff is like speaking Spanish to me. Lol. It just sucks, I like temp control, but wish I didn't get a dna. I didn't realize it was going to be this difficult. I need a cigarette after every time I mess with this thing....smh. kind of defeats the purpose.
No matter what I do, what settings I change, when I run the device monitor, temp doesn't even register. Temp control doesn't work.
I definitely will. I work night shift, so I'll probably get a chance to post on the morning.....Thanks !
What was the fix for this? Are you not supposed to have temp dominate checked? I'm using ss316l from steam, and it reads off no matter what build or atty.
