You can use à SS wire that can be used in both watt and TC. Kanthal is not a TC wire.
You can setup preheat as explained further below in another thread I just answered.
There is a philosophy behind a DNA chip which explains why there is not a preheat functionality in the chip. If you search through the forum there is a thread talking about this. The DNA is a great chip, surely the best on the market that renders great flavour better than any other chip I have used (subjective statement based on my personal taste). Mind you, yihi chip I have not tried but only tested the TC on it from a friend and I do not like the "pulsing" it created while firing in TC mode.
HTH,
Joel.
You will need to manually tweak the resistance until it works. To do so, you will also need to lock the resistance. You do this while your device is connected to escribe software. Example, my resistance is showing 0.23. I will then try 0.20, 21, 22 etc until it works. You can also start with 0.24, .25, etc.
Read the whole thread, it contains all you need to get this working.
HTH,
Joel.
Did some quick research and it seems that the DNA200 may have some issues in TC mode with builds under .05 ohms in TC mode especially(perhaps only) in NI200. Hence, the vape is waaaaayyyy smoother and on par when you lock ohms.
My SS316L is 0.53 ohms and I get excellent vape locked or not. On the .23 ohms NI200 hrakles, it needs to be locked around .28 for a good vape - so I ageee with arby.
For an unknown reason, when I attach the tank ( Heracles sense NI200) to my mod,'0.27 ohms is detected. After several vapes, ten or so, the ohm drops to 0.23 (mod seems to turn on) and then there is no way to get a satisfactory vapor, exactly what brought me to advise aabbas to lock the resistance.
Ok. I have unlocked my serpent mini with a SS316L at 0.52 and she's vaping great!!! I usually get issues when vaping on a 0.2 ohm Heracles sense NI200 coil. Usually reading at .32 when new and moving towards 0.23 as it gets used. I will give it a shot later tonight and report back.
I'm using a DNA200 on a Triade. Looking around this seems to be a must practice to lock the OHMS in cold when using Temp Control. All the vids I have seen from Rip Tripper, VapnFagan, Mike Vapes, indoor smokers, etc... they all lock the resistance when vaping in temperature control. Anyway, it does not work when not locked. Technically, not sure why it must be done, but it must be done. Thanks, Joel.
