S_wilson
  • Full Name
    Shane Wilson
    Tennesse
    SVA DNA75
S_wilson's Achievements
  1. I used the TFR curve CSV file from steam engine for Nifethal 52(alloy 52) But 0.00405 is the TCR value for zivipf. Since I started this post I have used niFe48 a good bit. For me spacing made a huge difference. The more spaced the better for me.
  2. Switched to spaced coils with NiFe30 & NiFe48. Resistance is now stable & TC works as it should.
  3. Ahh, ok thanks!!
  4. As posted earlier I am new to escribe. I have been trying to use the 2 above wires for the last few days. I am using the CSV files from SE for Nifethal 52 & Nifethal 70. When I use either of these wires everything starts out ok working under their temp profile. But after a few minutes the resistance rises up mod goes into watts mode. Then maybe later temp starts working again. This switch usually happens when I put mod down for a few minutes. So far I have checked 510 on mod, used 3 different atties with varying set ups of wire from single to dual coils & made sure my profiles had correct wire type & CSV in them. This happens with them all. I am using contact coils that have been dry burned & maybe that is the problem. Since I am new to the dna75 I wasn't sure if there is something else I'm missing. I have read that you don't have to lock resistance on the 75 or 200 so I haven't been. Not even sure if that is possible unless u have it connected to escribe. BTW I have used ni200 & it works as should in the Ni profile of course with these I use spaced coils.
  5. I am new to the forum as well as escibe. I have been watching several tutorials & believe I have everything set right for my dna75. But the examples I watched seem to be slightly different from current software version. I have 2 questions: 1. Is the atomizer analyzer button still available? Have profiles loaded and say I am under GENERAL TAB then PROFILE 1,2, etc From what I saw AA should be at bottom of the page but it is not on my screen. 2. Loading profiles correctly? Now it looks like you go under MATERIALS tab then import material/CSV from SE then put said material on device. Then under GENERAL , Profile 1 you just select that material & you are good to go. Correct? Thanks in advance!
