StirCwazy
StirCwazy's Achievements
  1. Much appreciated jka!
  2. Does anyone know where I can get a discharge profile (CSV) for the basen black 26650? This guy right here.
  3. I don't know if this has been said in this post, but please read anyway. Some, or maybe all, of the Lost Vape EFusion, from what I'm seeing, are being shipped with the default configuration of 2 cells. If you own one, please hook it up to your computer, launch EScribe, go to the Mod tab and verify your device is set to 3 cells! Also check your Watt Hours. They incorrectly set the default configuration so it should be set to 14.43Wh.
  4. Just a quick bump, would still like to receive some feedback from someone with Evolv so I'd know if this was even a possibility.
  5. Take a look at this thread. /topic/67027-topic/?do=findComment&comment=903151
  6. Doesn't look like it's making any headway with the Evolv folks. Oh well, suggestion made, would love to see it.
  7. I originally posted my suggestion/request in the wrong area of the forums. I'm not sure if anyone from Evolv has seen it, so I'm posting it here in hopes someone sees it who can say yes/no on making it happen. Suggestion was: Would it be possible to have the screen fields change per profile? For example, I've got several standard wattage profiles and several temp control profiles. While on wattage profiles I like to have things like ohm, voltage and battery percent. While on temp control profiles I'd like to mix it up and have ohm, voltage and temp. Would it be possible to make the fields available on the profiles to change what fields you want displayed per profile? There are others out there who seemed to like the idea, so here's the link to the original post. /topic/68317-topic/?do=findComment&comment=914383
  8. Maybe one of the evolv guys will see this one day I guess because I posted it in the wrong place that kind of screwed things up.
  9. I did a quick look and didn't see anything, so my apologies if I overlooked it. I thought I would post a feature request for the EScribe software. Would it be possible to have the screen fields change per profile? For example, I've got several standard wattage profiles and several temp control profiles. While on wattage profiles I like to have things like ohm, voltage and battery percent. While on temp control profiles I'd like to mix it up and have ohm, voltage and temp. Would it be possible to make the fields available on the profiles to change what fields you want displayed per profile? I'm loving the DNA200, awesome work you guys, by far my favorite chip to date. Chad My apologies, I completely overlooked the software section when posting this. I realize now that I posted in the wrong section. If it can be moved, please do so, if not, sorry!
