Hi the four torx screws on top and bottom of the SBODY Legend DNA 75,where would I be able to buy new screws from mine are starting to round out and want to put new ones in,also as they are rounding out I cant get them as tight as they should be ,any help would be greatly appreciated thank you in advance..
Ok got the set today ,pulled it apart and tightened al the screws the were a lil loose, and so were the body screws, and the screws that hold down the positive contact were also loose,It might be me but it seems to be hitting much harder now,I was set a 26watts but seem to be getting about the same at 20 watts ,is that possible..
ok thank you ill chase sum up n see what I can find out..DO you know about what size tore i need ,,I've been looking them up i can get a set of T3 to T6 will T3 be small enough or do i need a T1 or T2...thanks
So basically I have to get the screws tightened on the board some how...Is it hard to get one of this star tools..Just at my local hard ware s tore or something???
yes standing voltage is only 3.9volts...I thought it was weird and very high compare o what ive experienced with my other mods....Don't know what to do??
ok yes I ouldnt know where to start at pulling this apart there is only four screw I can see and they are those star type screw heads not alum,phillips or flat shaped like a star..two on top next 510..and two on bottom either side of battery cap...What sort of performance should I be expectring from a single 26650.....at 34watts at 0.54 ohms should I be able to go till the battery is flat as I'm only making it to 40% max......I had an evic mini and it performed better than this..Such a shame for such an expensive mod...
Hi yes have checked for battery sag...and depending on the level of charge how far it drops, but when this prob starts happening sags to about 2.75 volts...Yes ill try cleaning the battery cap threads, however the mod is brand new, only 1 week old....Yes thats what i felt the power isn't getting to the board..
Hi I have bought a SBODY LEGEND DNA 75...I bought the IJOY 4200mah 26650 and an efest green 4200mah 26650...Any way the IJOY is meant to be the best 26650 out...And Im getting horrible batter life Im running a 0.54 ohm coil at 34watts and at about 60-70% of battery the battery icon starts to flash and it won't fire the full 34 watts.When I check the battery on my charger it shows it is still at around 3.9volts...It is driving me mad I have run battery analyser to no avail...And have tried a few things with escribe settings...Its only drawing like 8amps from the battery and The IJOY battery is rated for 30amps(by mooch) ands should at least do 20amps..So how come it is dropping off the power so quick???
