Andy-d
    UK
    triade
Andy-d's Achievements
  1. and the keyboard warrior of the day steps up ,, swings ,, and misses,,
  2. yet,, hehehe and,,give them time on the "feet stamping" *roumour has it nasa maybe on notice incase of dummy launches,,, (allegedly) i fear tho that i dont qualify for the popcorn, as i am More than happy with the dna75c as i bought it, but thats what happens when adults apply "informed choices" to purchases not "OMG OMG new shiny oooo led lights and flashing oooo shiny" , but im a fan of the signal coming out of evolv boards since the dna 20 days,, and mastered the black art of temp limiting with the dna40,,,,,,not that it IS a black art , or complex or difficult (but i dont have a YT channel so it doesnt Need to be as ,,, i haz no ego to feed ,,,)
  3. @retird while certain folk "get" things like "testing" etc and,, are happy waiting as evolv "does exactly what it says on the tin" there will always be and nowt we say/do can change that,, etc ,,,
  4. irony "those who dont understand temp",,, "trouble using multi core / multi strand coils",,,
  5. 220C is "safe" for muji 240c is where I get very noticable brown/char point not tried cotton bacon ,, and do not bother with the BS "for vapours" so called special cottons
  6. i hope @James or @Brandon will correct me if i am wrong here temp control wasnt designed to vape at "that temp" , it was designed to "fix" (cure) the problem of the Many nastie "things" created by a dry hit / burning/over heated wicking material , making vaping Safer for vapers, And while doing that Prevent the fracturing of the eliquid (which when over heated Also produces lots of nasty things we dont want) common , yes sadly far far too many use it not as intended with contact / multi core wires and then "ah temp control is shite" gets said ,, it isnt when used correctly,, it is when used not as intended bit like using a screw driver to screw screws in , works perfect,, Sucks when you try to chop a tree down with one,,
  7. i pick the mode to match the coil wire SS316l for Ss 316l Nickle 200 for ni200 nife30 for nife30 (i only use dicodes own nife30) , profile for there wire @ steamengine.org its how ive been making coild for temp limited vaping since the dna40 was first released, Never had a single issue this way,
  8. or you Could Use the tech as it was designed to be used , it makes life And the vape So much more consistent and satisfying Wind a Spaced coil to Fit the deck of the atty you are using, do not fuss What the resistance is that it comes to . (cheat if you wish and use a machine screw to wind your coil around, the threads will give you a Very consistent and neat coil) Wick it , then dial your temp to a number Just below where the cotton / rayon/other starts to char / go brown , set + forget temp rewick fill with juice,, press +/- on the wattage and enjoy the vape you like at the watts you like, Without any risk of dry hit/burnt wick / burnt juice Consistant toot each + every time,, the DNA board "deals" with the math for the temp, deals with the wattage you want,, you , fill /toot/refill/toot and just enjoy a Nice crisp clean consistent toot
  9. cant i just enjoy the dna75c for what it is,, and know that "some time" in the future the Silly cheap Lost vape mirage with dna75c in it will get an upgrade to firmware Temp limiting Works, works well, Happy with that the ability to run NiFe30 wire, or Ni200 , "happy with that"
  10. Many thanks, i shall apply for my "cant see for looking badge " totally couldnt find that
  11. if someone could be so kind as to let me know How to download the "new" version of escribe , with the theme generator/etc for the DNA75C id be thankfull I Was about to buy a dna60 then as brandon + p busardo announced the DNA75C thats "next" but want to get a handle on the themes /screenw Before i get the device so i can load it instantly with the theme/screens and layouts I want thanks
