I resolve this issue by removing the yellowish plastic that wrapping dna board. So far i haven't received too hot error. It has been two days.
Why is it expensive mods keep having issue, used evic vtc mini for two years without any problem.
Thia is my second store bought dna that having problem. The one that i diy myself dont have any problem, except the look of it.
can some explain it in english, i can't understand from google translate. how is the washer is connected to the 510 plate? soldered or just a touch connection?
I have managed to solve unstable resistance value on my vt75 nano without soldering.
What i did was remove the pointy tip on top of positive 510 connector using a file. This can be done by disassemble the 510 connector. Once pointy tip was removed, i tighten the 510 plate(negative terminal) to C frame.
Tested with escribe device monitor, the graph is even smooth compared to before the changes. So far the resistance value is stable.
Any one got any idea how to permanently fix this. From my experience, all this problem is due to non-solder connection. This non-solder connection will formed oxidised layer over the time and cause unstable resistance.
Hope someone creative can come up with good idea. Or may be a new C frame that is pre-installed with 510 plate.
