Nope, tried the default settings - same. If the brightness of charging is set anywhere above 0%, it'll go there and show the battery %. It won't turn the screen off even when you select "Turn off screen after firing". Tried helloimage fix again - same results: it works for ~15minutes, then lights up to the charging screen. Also, the red light stays lit after unplugging the cable until the Fire button is pressed, but that was before then too. If you unplug the cable while there is no atty on the mod, you can't turn that red light off with no buttons. Attach an atty, press fire, then it goes away. Tested soft reset, hard reset, latest firmware, newest firmware again - nuffin. Any ideas? Should I report it in the Bugs section? Thanks, R
