AlbSteve
  • Full Name
    Stephen Tyldesley
    Albuquerque
    DX200
AlbSteve's Achievements
  1. "Did you measure continuity from each ground (mounting holes) to B-". With holes drilled lost continuity to mounting hole and B-. After filling mounting hole with solder, continuity returned from all mounting holes to B-. "Did you measure continuity from B- to the the atty ground connection at the atty?" - yes, has continuity. "Did you measure from the negative atty pad at the board to the negative connection at the atty?" -yes has continuity. Soldered 1 ohm high watt resistor to output, no atty used, very positive connection. "Did the board work prior to you drilling the holes bigger?" - never tested prior to drilling. I did previously , drill out a 75C successfully. Assumed this would work.
  2. AlbSteve
    Check atomizer
    DNA 75 board. The board says check atomizer, when a 1 ohm resistance is at the board. Display reports 0.00 ohms. Drilled the mounting screw holes to 2.1 mm. The board no longer reads resistance. Filled the mounting screws holes with solder. The board still will not read resistance. Can measure the 1 ohm resistance on the board pads with a meter. Wiring, 510 ect. not the problem. Any idea's to get the board to function properly?
  3. How to open the screen socket on the board? Thank you.
  4. Going to build a dna 75 mod 1) will installing 18650 battery backwards fry the board? 2) will be using a remote switch for the fire button, wish to use small gauge wires for fire button. What is the amp. rating for the remote fire switch? 3) thinking about trying to cut a cell phone screen cover (glass) to make a dna screen cover. Are there any pre made screen covers? Are there any screen cover holders? 4) would like to use a remote USB port. Not the port on the evolv board. A USB extension. I believe it's a micro B USB port. Any sources for making this cable? Thank you!
