Built with Factory Enhanced Platform to keep everything working including Replay.
Several modifications keeping the overall default Evolv theme Capabilities.
Simpsons Walpaper Theme Very colorful
New Coil Info screen added with time, battery %, current profile, coil material, cold ohms, live ohms, coild temp, ability to remeasure resistenace, and ability to lock ohms.
New Display menu has brightness adjustment, always on, stealth level, auto lock, auto lock time out, and # of clicks to lock, and ability to set unluck device sequence.
Device screen now had power bank settings, and battery voltages for up to 4 batteries.
About Menu with Lifetime puff count, Theme revision,  current firmware, current revision, edition, current puff count, puff count total energy, and reset to take you to a rest statistics screen.
Thanks to everyone on the Evolv forum for ideas and themes to give me inspiration for this theme.
What's New in Version 1.0.1   See changelog
Several modifications keeping the overall default Evolv Them But with Simpons Wallpapeand everything is very colorful now.
New coil install screen now has new coil and old coil resistance when deciding on new coil or keeping old settings.
Simpsons Colorful Theme Think Vape Finder 250C.ecigtheme
