This is a template only for DNA250C! Will not work on DNA75C! - there is not enough internal memory. Replay and Power bank menus.
The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Copy from VapingBad
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
In Lock Screen down: Current in charge or root temperature in non charging mode.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power: temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
Power Bank work on DNA250C video - sorry, but it's only in Bulgarian. Max output current - 1,9 Amps. It is mandatory to use the USB OTG cable!!
New version ...
Copyman-DNA250C-Circle.ecigtheme
