A replay centric near stock DNA 250C theme.
YOU MUST ENABLE REPLAY ON PROFILES FOR THE REPLAY BUTTON TO WORK.
The bottom left number adjusts warmth, the center button toggles replay, and the gear takes you to the settings menu.
Thunder Dick
DONG MAGNUM I JUST WANTED TO LET YOU KNOW THAT MY NAME IS BETTER !
rask116
· Edited by rask116
First let me say, that for a Basic Default styled profile, I like this, it's awesome! The reason for 4 stars and not 5, is because of the (I guess) puff counter thing under the temp setting on the main screen.  I'd personally rather have the voltage and amps show there. But I'm not salty enough  (at all at present)  with the Theme designer to attempt putting it in and taking what you have there out. I can't see or tell what that thing is on my  Thinkvape Finder 250c I just got 3 days ago anyway. I like your theme simply because I can see the thing outside, whereas many of these offered themes here offered at escribe forum I can't see at all if I'm in my car or outside.  But thank you for this. Works well so far.
