Information:
The theme is based on my previous themes. It works on DNA75C, DNA100C, DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. Supports replay.  Supports the new Season Mode feature - Works only with Escribe SP45 and firmware 1.1 SP 55.1
On the idea of vapingbad - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Preheat:
Preheating has several states: 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false.
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power:  temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
In Main Screen top:  The name of the profile below is the material used
In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts (approximate values)
New:  Added on/off of Session Mode on the main screen and timer setting in profile and settings
Review with presentation of the work of the feature - has subtitles:
Smoking Maniac Youtube chanel
Hadron-V1.6-sesion.ecigtheme
Edited by copyman
Add link to review
What's New in Version 1.6   See changelog
Version for Hadron mini
