See also my other Themes:
What's New in Version 11/05/2021 12:10 PM See changelog
TC mode:
Even if I continue to take the position that the direct, numerical input of the preheat temperature does not make sense, based on user feedback I have created the possibility to choose between direct, numerical input and the previous preselection of the preheat temperature as a punch.
When preselecting via Preheatpunch, the temperature is preselected in 11 fixed steps, the level of which is determined by the chipset based on the TC target temperature. The existing preheat time is much too short for a more precise temperature control.
Veröffentlicht 30. Oktober
- all versions: smallest detail corrections and changed 12/24 hour changeover
- "silver" version: corrected background
Veröffentlicht 12. Oktober
- Detailed work and bug fix in the temperature warning, this has been repositioned (even if it will hopefully never be seen by anyone)
- New layout of the battery screen, better adaptation to the number of cells used
V7xx2.8: REPLAY control no longer in accent color green, but follows the normal color scheme in the sense of better readability in a bright environment
(the old version 7xx2.7 with accent color remains available in the download area)
