escribe wont open
yeah my laptop came with avg and the lifetime key so its what ive been using. But malwarebytes is an light weight program and scan pretty fast for the full complete scan. it just sucks i cant use escribe lol, i finally got and dna 200 and this happens. this vt133 is a really nice dna battery life last me full day. was hoping to customize it tho.
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Have you looked in the application event log?  Also I wonder is any disabled services may affect it, my start menu would not open, notifications were not working plus a few other things in Win 10 with the firewall disabled.  Also you could try .net fusion logging https://msdn.microsoft.com/en-us/library/e74a18c4(v=vs.110).aspx
germanguy45 said:
At Vapingbad the application event log: what is that
At retird i downloaded it from and thread in this forum and from the evolve website,
Control panel - administrative tools - event viewer - application log
It varies between windows versions, just have good look at errors and warnings.
this is what it says
Faulting application name: EScribe.exe, version: 0.0.0.0, time stamp: 0x57a929af
Faulting module name: clr.dll, version: 4.0.30319.34209, time stamp: 0x5348961e
Exception code: 0xc0000005
Fault offset: 0x00032bd1
Faulting process id: 0x125c
Faulting application start time: 0x01d203b1112e2b2c
Faulting application path: C:\Users\Admin\AppData\Roaming\Evolv\EScribe Suite\EScribe.exe
Faulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
Report Id: 4f735e71-6fa4-11e6-a33d-5c260a2b3adc
Application: escribe.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an internal error in the .NET Runtime at IP 6A662BD1 (6A630000) with exit code 80131506.
That is the MS dot net common language runtime engine, it confirms that EScrib is encountering an error but not what it is, probably a version mismatch between EScribe and another component it uses.  Try running the installer again with just services packs checked in the install options.
It could be almost anything https://www.google.co.uk/search?num=100&newwindow=1&q=.NET+Runtime++exit+code+80131506&oq=.NET+Runtime++exit+code+80131506&gs_l=serp.12...12495.14072.0.15343.2.2.0.0.0.0.75.146.2.2.0....0...1c..64.serp..0.0.0.4lDT6H5s-hI
Are you running it in a language other than English, if so you try changing the Local to English the see if the translation is an issue.
Try the Visual Basic 6 runtime https://www.microsoft.com/en-us/download/details.aspx?id=24417  it is a long shot, but one of the components EScribe uses may use something that references that.  Also the Visual C++ redistributable, but ther are lots of releases http://www.howtogeek.com/256245/why-are-there-so-many-microsoft-visual-c-redistributables-installed-on-my-pc/  there are links to the packages near the end, the x86 ones would more likely be referenced by components.
Both long shots, but if you are thinking about wiping your PC and starting over...
will try this and report back
well I got it to work, it turns out that I got an bad download multiple times. so i downloaded from my friend house and transfer it to my laptop and bam works. I just have another problem now anytime I turnsikesory and download something or upload something I get a error. it's saying failed to detect eeprom or something like that
