vegabob
510 99.9 pure copper Mod resistance tools
68 posts in this topic
Spirometry said:
SP3 added some extra protections. Reading the ultra low resistances with the copper plug will just display a question mark.
Thanks! That's odd though since when I wrote my posts earlier in this thread, I believe I was using SP3. I did see the "?", but after making the plug really tight, it showed the resistance. I could be mistaken on the SP version I was using at the time. I do hope they fix the issue.
Share this post
Link to post
Wayneo said:
Has anyone managed to retest with this latest SP5 to see if this is working again? I know mine is somwhere around here, I'll just have to hunt it down.
I just ran SP5, on my new VS Switchbox DBA75, which came from VS with a ".004" already set. Zeroed settings, use the copper plug, and got the EXACT same number. So I would say it worked!
Share this post
Link to post
6-5-2016 is the latest firmware version for the DNA75.  Check the lower right hand corner of Device Monitor and the Switchbox should show that version.
Vapor Shark did an excellent job programming the Switchbox with the production utility.
Share this post
Link to post
mactavish said:
... new VS Switchbox DBA75, which came from VS with a ".004" already set.
Very sharp looking mod. Thanks for trying.
When I ran it with the Feb software, I fely very uncomfortable with how much I tightened it down, especially on my Reuleaux, knowing the quality of that 510.
Share this post
Link to post
You are welcome. With SP5 I did NOT have over tighten, but I did not test that aspect on any of my other DNA devices.
Share this post
Link to post
Has anyone managed to retest with this latest EScribe 1.2 SP5.2 to see if this is working again?
Or even better, is it on any official list for it to be fixed in the future, which should then show up in the notes for each new release.
Share this post
Link to post
Best I can tell, just checked a few of mine, is that it still doesn't function properly. EScribe 1.2 SP5.2 on my computer has firmware for 200/250 dated 12-22-2016. Still shows "?"
Share this post
Link to post
I'm just waiting on a few last parts before getting myself a new mod built and I'll need to run my own MFG settings. Luckily I have an old version 2016/02/23 which works.
Share this post
Link to post
56 minutes ago, Zaptear said:
Can’t u just short out ur rda with copper wire to do the same thing ?
You can, but there is a slight amount of resistance in the wire as well....
Share this post
Link to post
Thanks this is my dna 250 from Modz by nasy trying to find a discharge profile for a max amps 1850 mah 3s
Share this post
Link to post
7 minutes ago, Zaptear said:
Link not working
Just clicked it on an iPad opened fine in Safari. Check your internet settings.
Share this post
Link to post
Share this post
Link to post
Yo @mactavish, the url you show (that works), is not the same as his on his mobile. (:
His 'fix' I'd betcha is written on his image posted.
Share this post
Link to post
