Frank65
  • Content Count
    93
Everything posted by Frank65
  1. Version 1.4.0
    2,843 downloads
    Rev 1.4.0 Replay ready
  2. Version 1.0.0
    236 downloads
    Jac Vapour theme for DNA75
  3. Version 2.8.8.1
    31,647 downloads
    Full options theme with Replay. Rev 2.8.8 - March 2019
  4. Frank65
    Conditional Automatic Toggle
    hello Unfortunately what you're asking it's not possible as far as I know 😕
  5. Frank65
    K.I.S.S
    Something original , I like this.
  6. Added ! Hope you like it Very nice box you lucky man 😁
  7. Easy way : from Theme Designer , under first label Appearance , set Wallpaper to None.
  8. Yes I think that's a theme error , I'm going to fix it next release (hopefully soon).
  9. Hello , open the theme with theme editor , on top right see button SPACE USED , that is showing you % of board memory used. Filesize doesn't matter.
  10. Hello I think that when you fire it the resistance impedance getting higher is very normal . Actually I'm vaping on a ni200 0.25ohm coil in TC and when I fire it jumps to 0.45ohm , locked or not. I'm not a DNA guru , been reading this : https://ziggicig.com/why-does-my-coil-resistance-keep-changing/ 😁 Sorry ,maybe if you ask directly in the forum I'm sure you can get better help !
  11. Yep that's true I can replicate that. That's strange because in the theme the only condition for lock icon to be hidden is temp sensing material is not true and this condition is true if replay is working😲 Anyway , if you remove the above condition , you can lock the coil no matter what , I've attached a modified theme for you , please check and let me know if it works. Regards TEST_LOCK.ecigtheme
  12. Hello I'm not sure to understand 100% , but as far as I know no locking is necessary in replay mode. Said that , you see no lock icon with that coil because the firmware doesn't recognize it as a temperature sensing material. Try with a simple TC wire and then you will be able to lock it. The lock icon in the theme is hidden if "coil temp sensing material" is "untrue" . I think this problem is firmware related , not theme. Take a look at this thread , there is a patch you can try (at your risk ):
  13. Hello To lock the resistance : from the main menu select the ohm values and click , you go in the coil menu (see below) , where you can lock the coil You cannot do that directly from the theme , but from theme designer : open the theme with theme designer -> Appareance menu -> Fading -> Active time (modify this field as you wish and save\upload theme to your mod) @FrankV
  14. Yep you're right , on Escribe you can choose punch OR temp , I will check for a solution on new theme revision. Thanks for finding this bug !
  15. Hello Yes that's correct , it was wrong in previous versions , now it should work as expected.
  16. Hello Probably your coil is not replay compatible , what material are you using ? Does the screen shows Save icon ?
  17. Hello They're talking about this in this topic. James from Evolve says : My opinion is that replay is working in TC , and it records the last TC puff trying to replay it. Don't know if this answer your question , but yes I would use replay AND TC with Titanium coil 🙄
  18. Hi If you want send me your theme and i'll check it
  19. Hello I mean the dimension you can see by selecting on theme editor your object\picture , clicking ACTIONS button on the right , then RESIZE.
  20. No they don't have the same size , otherwise you should not see that message. Double check 🙄
  21. Hello Loxias Happy you like my theme. Maybe the DNA firmware (the theme is just aesthetic , you cannot decide data refresh time or modify the logic) has a lower refresh of Device Monitor. So I think the lag on preheat indication is not something you can modify and it's common to all themes. Maybe you can try a simpler theme and see if it reacts faster... ?
