   (1 review)
PLEASE NOTE:
TO THE EXPERIENCED USERS:
Disclaimer:
Haftungsausschluss:
What's New in Version basic V2   See changelog
V2: I have incorporated extensive changes that are not visible at first glance.
The most obvious is the fact that the switch between the individual operating modes no longer has to be confirmed with the fire button; the display changes immediately (only the change of wire type must still be completed by pressing the Firebutton, since the wire is tested internally).
Otherwise, the theme runs more smoothly and further, better warnings in the case of incorrect, unpredictable operating mode, and low battery are added.
zark
Report ·
Share this review
