   (1 review)
PLEASE NOTE:
TO THE EXPERIENCED USERS:
Disclaimer:
Haftungsausschluss:
What's New in Version 3.7.1   See changelog
- some really nice, graphical detail corrections on the lockscreen, especially when loading
another background
- further graphic detail work on the SCARLET-PASSION version with SQUAPE logo; it is becoming my favorite version
- - the changes are unfortunately not visible in the screenshot, as they affect the toggles and replay control ... :unamused:
zark
Report ·
Share this review
