   (1 review)
PLEASE NOTE:
TO THE EXPERIENCED USERS:
Disclaimer:
Haftungsausschluss:
What's New in Version V3.1   See changelog
V3.1: small bugfix on the lockscreen
(only occurred if replay was activated, but no puff was saved. Version "StattQualm" is not affected due to the different layout)
V3: - contrary to my original intention, I saw the need to add another screen - "Profile".
In addition to the direct selection of a profile, the resistance query can be locked ("Lock Resistance") and the suitability of the coil can be tested (TSM detect) if a TempSensitive material is selected.
With the "Fire" button, the new wire selection is immediately confirmed for the system, the coil is tested internally and a possible change between power and TC mode is carried out.
V2.9: - the new atomizer screen is also colored red in battery less or equal than 5%
V2.8: Function update:
- Similar to the mainscreen, a clear battery warning on the lockscreen, but here depending on the set power: over 20W at 15% and less, below 20W at 5% and less (on the mainscreen generally at 5% and less)
V2.7: - small change on the "New Atty" screen
- Since I started the theme about 6 months ago, I had a tiny display problem on the main screen, which probably only bothered me.
Eliminating the problem always resulted in 1.) exceeding the control limit, 2.) exceeding the memory limit, or 3.) flickering of the screen.
Well, I woke up this morning with an inspiration - the solution was amazingly easy. Thus the graphic development of the theme is finished.
Here I publish my personal theme.
I use it on my paranormal, only with atomizers from StattQualm and VaporGiant.
Since I only use my Squape above 0.3Ω, my VapoGiant below 0.2Ω, the "NewAtty" screen is displayed every time I change the atomizer, so that I can / have to change the profile there.
In this way it is possible for me to assign a suitable logo on the lockscreen to each atomizer; Profiles 1 to 4 are reserved for StattQualm atomizers and profiles 5 to 8 are reserved for VaporGiant atomizers.
Of course it looks great if you have previously renamed the profiles in Escribe to match the atomizers 😉
(In the screenshot, profile 1 is active on the left - renamed "N [duro] SCR". On the right, profile 5 is renamed "KRONOS". Otherwise, only "profile 1" would be displayed as an example)
V2.6: - I redesigned the NewAtomizer screen
V2.5: since it is my daily theme, I made some small visual changes ...
As inconspicuous as they are, they took a lot of time until I was satisfied.
V2.1: I have made minor changes in the color, as well as the manual measurement of the resistance and display of the same
V2: I have incorporated extensive changes that are not visible at first glance.
The most obvious is the fact that the switch between the individual operating modes no longer has to be confirmed with the fire button; the display changes immediately (only the change of wire type must still be completed by pressing the Firebutton, since the wire is tested internally).
Otherwise, the theme runs more smoothly and further, better warnings in the case of incorrect, unpredictable operating mode, and low battery are added.
zark
Report ·
Share this review
