Unfortunately, the preview is not complete - look at my own screenshot
PLEASE NOTE: The change of wire type must still be completed by pressing the firebutton, since the wire is tested internally
What's New in Version V2.1   See changelog
V2.1: I have made minor changes in the color, as well as the manual measurement of the resistance and display of the same
V2: I have incorporated extensive changes that are not visible at first glance.
The most obvious is the fact that the switch between the individual operating modes no longer has to be confirmed with the fire button; the display changes immediately (only the change of wire type must still be completed by pressing the Firebutton, since the wire is tested internally).
Otherwise, the theme runs more smoothly and further, better warnings in the case of incorrect, unpredictable operating mode, and low battery are added.
zark
Report ·
Share this review
