Unfortunately, the preview is not complete - look at my own screenshot
PLEASE NOTE: The change of wire type must still be completed by pressing the firebutton, since the wire is tested internally
What's New in Version V2.1   See changelog
V2.1: I have made minor changes in the color, as well as the manual measurement of the resistance and display of the same
V2: I have incorporated extensive changes that are not visible at first glance.
The most obvious is the fact that the switch between the individual operating modes no longer has to be confirmed with the fire button; the display changes immediately (only the change of wire type must still be completed by pressing the Firebutton, since the wire is tested internally).
Otherwise, the theme runs more smoothly and further, better warnings in the case of incorrect, unpredictable operating mode, and low battery are added.
Recommended Comments
vor 5 Stunden schrieb gwyar:
I'll be adding two things over the next few days: a status indicator during firing and a way to manually re-measure the COIL... 😉
I DID IT!
- added the possibility to re-measure a coil manually; it's a shortcut to the New Atomizer screen, which I've redesigned
Share this comment
Сейчас у меня нет возможности протестировать эту тему, но по собственному опыту, думаю, что из за большого количества наслоений и использования функции Hidden, окно Status, расположенное на главном экране, будет заметно мигать при нажатии кнопки Fire. Повторяю, это мои теоретические выводы.
Share this comment
vor einer Stunde schrieb zark:
"... aufgrund der großen Anzahl von Ebenen und der Verwendung der versteckten Funktion, das Status-Fenster, auf dem Hauptbildschirm, auf Knopfdruck merklich blinken wird. Ich wiederhole, das sind meine theoretischen Schlussfolgerungen.
Diese Problematik ist mir früher auch begegnet - heute vermeide ich diese Konflikte, indem ich die verschiedenen Ebenen in den Bedingungen gegeneinander ausschließe.
Hier habe ich es so gelöst, dass das Status-Fenster nur angezeigt wird, wenn die Bedingung "Firing" erfüllt ist; die anderen Anzeigen sind jedoch nur sichtbar, wenn die Bedingung "Firing" nicht erfüllt ist.
Diese Vorgehensweise ist zwar mühsam, aber - wenn nichts übersehen wurde - lässt sich auf diesem Weg ein Blinken oder Flackern überlagerter Ebenen sehr gut vermeiden.
Share this comment
I have tested this version extensively without being conspicuous - but of course I am not immune to errors ...
If you notice any errors, even if the display is only flickering, please report them to me.
Share this comment
