less complex, but complete - only English
- all protections against erroneous settings (eg Temp-Protect in power mode), as usual from my other enhaced themes
- if replay is activated, the functions on the main screen only appear if the coil is replayable
- the menu adapts to the capabilities of the chipset; the Powerbank function is not displayed on the 75c and the screen layout is adjusted accordingly
- Only the readable cells are displayed in the battery overview, maximum 4 (250c). When the cells are connected in parallel (75c, Therion), the voltage is generally displayed
- Battery indicator Lockscreen either in percent, or as a graphic display
- Logo on the Lockscreen switchable between "Lost Vape", or "StattQualm"
PLEASE NOTE - REPLAY IS FOR COIL MATERIAL "Watts" PROVIDED, NOT FOR SPECIFIC WIRES!
What's New in Version 1.5   See changelog
- Navigation changed; "Round Robin" only on exit down, from main screen exit up to lock the device
